Help With Insurgency
16 Jun 2005
Doncaster
I've just installed this css mod and all i see is purple & black everywhere, player models,roads etc...
also css works fine
i'm using an 8800gtx,vista 64bit,q6700,2gb ram
try restarting the game that normally works :D
if that doesnt work i dunno restarting it normally does it for me
hi,
hers a quote from their forum..........
Q) My screen is displaying everything as purple and black
A) The problem could rest in one of the following;
i) Turn your screen display in game to a lower resolution. Ie. From 1024 * 768 to a resolution of 800 * 600
ii) Make sure you have all the up-to-date drivers for your graphics card. The steam app should prompt you with a warning if you don't have them. But on the off chance its missing an update, check your video card manufacturers homepage for more details
iii) Are you running the client version of Insurgency? I have heard reports that some users are trying to run the Server version of the game rather then the client. Make sure your client download was the 600MB one, not the 250MB one
:o seems i downloaded wrong one, i'll download client one now :o
