Hi
Having some issues since last Friday. I have attached a routerstats log. If you see, my sync is set low with the dgteam firmware. I used to have no issues for months on end setting a 3db snr however since friday something has happened causing my line to drop around 3db snr on the downstream. I know snr moves around a lot but this seems to be extreme.
So i set routerstats up to see what was happening. As you can see, around 23:23 to 23:25 something happens and my line goes ''back to normal'' and stays like this till the morning when things go funny again.
Nothing has changed here. I tried new filters/the ring wire is removed/new rj11/disconnected telephone etc etc but i cannot find the issue.
The end drop is me resyncing to get back to ''normal speed''
Any ideas?
Any ideas?
