I wonder if someone can shed some light on this for me.
I have configured a MIP on a SSG5 to map to our FTP server.
When the remote site tries to connect to the FTP server it doesn't work, however I can see that the packets are hitting the firewall but it seems the reverse communication is getting confused.
Below is a debug flow basic output:
****** 257010.0: <ManagedNetwork/ethernet0/0> packet received [48]******
ipid = 22448(57b0), @03451b70
packet passed sanity check.
ethernet0/0:194.x.x.2/41400->10.x.x.194/21,6<Root>
no session found
flow_first_sanity_check: in <ethernet0/0>, out <N/A>
self check, not for us
chose interface ethernet0/0 as incoming nat if.
flow_first_routing: in <ethernet0/0>, out <N/A>
search route to (ethernet0/0, 194.x.x.2->10.10.10.2) in vr trust-vr for vsd-0/flag-0/ifp-null
[ Dest] 3.route 10.10.10.2->10.10.10.2, to ethernet0/1
routed (x_dst_ip 10.10.10.2) from ethernet0/0 (ethernet0/0 in 0) to ethernet0/1
policy search from zone 101-> zone 3
policy_flow_search policy search nat_crt from zone 101-> zone 10
RPC Mapping Table search returned 0 matched service(s) for (vsys Root, ip 10.x.x.194, port 21, proto 6)
No SW RPC rule match, search HW rule
swrs_search_ip: policy matched id/idx/action = 26/0/0x9
Permitted by policy 26
No src xlate choose interface ethernet0/1 as outgoing phy if
no loop on ifp ethernet0/1.
session application type 1, name FTP, nas_id 0, timeout 1800sec
ALG vector is attached
service lookup identified service 1.
flow_first_final_check: in <ethernet0/0>, out <ethernet0/1>
existing vector list 183-2c56a74.
Session (id:7103) created for first pak 183
flow_first_install_session======>
route to 10.10.10.2
arp entry found for 10.10.10.2
ifp2 ethernet0/1, out_ifp ethernet0/1, flag 00800800, tunnel ffffffff, rc 1
outgoing wing prepared, ready
handle cleartext reverse route
search route to (ethernet0/1, 10.10.10.2->194.x.x.2) in vr trust-vr for vsd-0/flag-3000/ifp-ethernet0/0
[ Dest] 14.route 194.x.x.2->10.x.x.193, to ethernet0/0
route to 10.x.x.193
arp lookup failed for 10.x.x.193
ifp2 ethernet0/0, out_ifp ethernet0/0, flag 00000801, tunnel ffffffff, rc 0
cache src mac in session for reverse direction
flow got session.
flow session id 7103
tcp seq check.
Got syn, 194.x.x.2(41400)->10.x.x.194(21), nspflag 0x200b801, 0x800800
post addr xlation: 194.x.x.2->10.10.10.2.
flow_send_vector_, vid = 0, is_layer2_if=0
packet send out to 00195b6c7f48 through ethernet0/1
****** 257010.0: <DMZ/ethernet0/1> packet received [48]******
ipid = 12979(32b3), @0354a050
ethernet0/1:10.10.10.2/21->194.x.x.2/41400,6<Root>
existing session found. sess token 13
flow got session.
tcp seq check.
Got syn_ack, 10.10.10.2(21)->194.x.x.2(41400), nspflag 0x801800, 0x200b801
post addr xlation: 10.x.x.194->194.x.x.2.
packet send out to 0013c4569108 through ethernet0/0
****** 257013.0: <ManagedNetwork/ethernet0/0> packet received [48]******
ipid = 22461(57bd), @03452b70
existing session found. sess token 17
flow got session.
tcp seq check.
Got syn, 194.x.x.2(41400)->10.x.x.194(21), nspflag 0x200b801, 0x801800
****** 257014.0: <DMZ/ethernet0/1> packet received [48]******
ipid = 12995(32c3), @03557050
flow got session.
tcp seq check.
****** 257019.0: <ManagedNetwork/ethernet0/0> packet received [48]******
ipid = 22482(57d2), @03453b70
flow got session.
tcp seq check.
****** 257020.0: <DMZ/ethernet0/1> packet received [48]******
ipid = 13034(32ea), @03578050
flow got session.
tcp seq check.
no session found
route to 10.10.10.2
route to 10.x.x.193
flow got session.
tcp seq check.
flow got session.
tcp seq check.
flow got session.
tcp seq check.
flow got session.
tcp seq check.
flow got session.
tcp seq check.
flow got session.
tcp seq check.
