Help with Kane and Lynch - Stuck!
26 Feb 2007
Around
ON the bit where you've just gone in to find the Seven in Panama. The helicopter keeps killing us. Is there anything that i should be doing here? I see there's loads of rocket launchers but i cant seem to actually hit the helicopter. Plus the myriad of soldiers just makes the whole thing impossible. Am i meant to hit it or dodge it or what?
Help :(
What i did was to get all my troops in the building on the right, the one with the machine gun, get them to stand in the end corner out of the way of the helicopter fire. Once the chopper had gone i would run out with another bloke incase i died to trigger the enemy troops then run back to were the rest of your troops are, you should have enough time to do this between chopper runs. Your troops should be able to take out the enemy from the house if not move them about inside till someone uses the machine gun to help. Use the RPGs to take out the two jeeps in the top right of the map, dont bother trying to shoot down the chopper, you dont need to, sometimes you can be lucky and you team will take it down with machine gun fire.
Enemies will spawn as you hit random points so move slowly and keep your men back, it's quite easy to predict where the chopper is going to go.
If you figure out the points that make the enemy spawn you can ru nout to a point then leg it back to cover as they spawn then pick them off.
That's how I ended up doing it, just take your time and try and pick off all the enemy troops.
You will get revenge on the chopper in the next area :p
That level really did my nut in! It's all about doing things in the right order. As wyrdo says enemies will spawn when you reach certain points so it's just a question of learning where these points are. This level is all about taking your time and clearing out as many of the enemy troops from long distances as possible. If you go charging in you'll just ripped to pieces by the many mounted guns over towards the back of the level.
The chopper takes 3 hits from the RPG to get rid. What I did to start with was tell everyone else to stay back behind the armoured truck and clear out the front selection of troops on my own. If you let your team in too early they'll just get shot to shreads.
Make your way up the first floor of the building on the right, kill the guy up there and call your team up there. They'll help clear out some of the enemies out in the square. While they're doing that grab an RPG and head over to the open "destroyed" part of that floor. Stand on the broken floorboards looking out towards the statue and the chopper will fly over the square towards you. Hit it with an RPG. Go grab the second RPG by the mounted gun and repeat. It can take a while for the chopper to come back but it will.
Send your team down to the statue thingy opposite and they should start using the mounted gun down there to clear out the area. Make your way across to the statue yourself, hiding behind the tank and taking out the guys around the gun truck on your way. Use the RPG's down there to take out the chopper.
From then on it's just a case of pushing forward taking out spawning troops as you go. Make sure you take out the mounted guns first as they will have you dead in seconds. I left my team at the statue until the whole area was clear as they're a liability and will just get themselves shot :)
HTH
Hi guys! Sorry i'm back cause im rubbish.
Im at the level where i have to save his daughter from the 2 brothers.......with all enemys on the balcony above.
What the hell im a meant to do as the minute they start shooting im dead......i dont even get time to run anywhere.....HELP!
Shoot the canister to the right of you. I think it's a canister, there's something there you need to make go BOOM.
