- 25 May 2011
I use gamestream via Nvidia sheild pad.. I have 1080ti with 2700k @4.5ghz 8GB Ram
Since using game stream I have never had an issue.. RE7 maxed on 4k TV @60fps
I bought BO3 today to play zombies (old favourite).... I notice as soon as the game starts it has a slight pause when I try and turn and doesn't feel fluid.
I notice it says NAT moderate?... Not sure if that's the issue?
I have lowered settings from 4k to 1600x??? And it still lags with movement.... I think my specs are good enough.
Any ideas what it might be?
The only thing I have changed is my Ethernet from 1gb to 100mb connection as it solved lots of issues with games not loading... Gamestream bug.
I have also put my 4k TV on game mode
Any ideas what the likely issue is?
