help with lag problems!
1 Mar 2007
Hi
I'm having problems playing 3d films on my pc. It lags and stutters regulary. Im pretty sure its not my graphics card not being good enough........(famous last words). I think maybe its my cpu or ram that isnt? Can your hard disk not be capable of transfering the data quick enough? Im not brilliant with computers so not sure. Bought my motherboard, processor and ram 3years ago so maybe due an upgrade? Anyway ive listed my computer spec below. I can provide more info if need be. Any help would be massively appreciated. Thankyou
Processor: AMD Athlon(tm) 64 x2 dual core processor 6000+ 3.10ghz
Motherboard: gigabyte m61pme-s2
RAM: 4gb, dane-elec ddr2 800mhz
Graphics card: Sapphire HD 5770 1gb gddr5
PSU: Corsair 650W tx series
hi, thanks for response. Ive just tried that at no change unfortunately. Im wondering whether its my average ram? ddr2 is pretty dated now isnt it? If it is that it would require a new motherboard etc wouldnt it? as mine cant upgrade above ddr2 i dont think
anybody else have any idea? my gut feeling is i need an upgrade on my motherboard,processor and ram, as they are dated. Any advice if so? my budget would be about 250 - 350
I have managed to watch something in 3d already but a smaller file than im trying to play now, so not sure about that...? even if i play the file from my hard drive on my normal monitor, it will show up in SBS screens but still lag and stutter
Any advice on upgrade? I want to keep my psu and graphics card. Im ok for hard drives as I have 3. Just need motherboard, processor, ram. Wud quite like a new case as mine a little cramped but priority wud be the upgrade. I think the upgrade wud sort my problem......(or am I making an excuse to upgrade cos I want to)!
