Hi guys, I am going to buy a RGB 60LED 5050 SMD with IR controller and I am wondering how would you connect this to your power supply. I have no idea HELP please!
Depends on how the PWM controller is powered. If it's like mine it's got a standard DC jack on one side that requires a 12v supply. Wiring this up to your PC power supply is simple enough.
Buying a genuine part from Bitfenix or similar will already come with Molex or similar connectors.
Buy a correctly sized DC jack for your controller, solder some wires to it, then solder the other end of the wires into a lead coming from your power supply. If it's a molex then it's the Yellow for +12v (usually the centre pin of a DC jack) and Black for ground (usually the collar of a DC jack). To free up a Molex for this you could get one of these...
