Help with limwire
Sam
Sam
12 Jan 2003
Surrey
Hi
Have allways used limewire to download LEGIT files and ive recentley made the step down ( some would sayn step up ;) ) back to XP and ive installed limewire and it wont work , it comes up with the logo box ( loading thing ) and thats it dosent open the prog
:\ It says on there troubleshooting to reinstall java which i have done but it still hasnt solved the problem
Any ideas ?
Sam
I do have a ATI Graphics card on the latest drivers
Box isnt grey its normal but it flashes up for about a seconds then dissapears
Tnx
Sam
Tnx
Sam
Ah damn, it's not the problem I was thinking of. Setting AntiAliasing to 'Application Controlled' doesn't help at all does it? If not, I'm afraid I can't help anymore. Sorry :/
Someone should be able to sort you out though :)
you could try, fully deleting lime wire from ** computer and then re-installing it, that is assuming ** using normal limewire and not limewire pro (the one u pay for). I had some probs wif mine then i did that and it works like a beauty now.
Alternatively, check the file location where you origonally saved limewire. If that file has been corrupted or forwatever reason limewire has been deleted or encoutered an error, the shortcut ** using to open limewire might be trying to open a program from the wrong place or isnt there to begin with.
Hi Mate
Just went into C: / Prog Files / Limewire and i clicked the exe and it did the same so its not the shortcut
BUT everytime i try to open it it makes a error note pad file which says the following
n unexpected error has been detected by Java Runtime Environment:
# EXCEPTION_STACK_OVERFLOW (0xc00000fd) at pc=0x032ca387, pid=3512, tid=2712
# Java VM: Java HotSpot(TM) Client VM (1.6.0_01-b06 mixed mode, sharing)
# Problematic frame:
# C [nvappfilter.dll+0xa387]
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
--------------- S Y S T E M ---------------
OS: Windows XP Build 2600 Service Pack 2
CPU:total 1 family 15, cmov, cx8, fxsr, mmx, sse, sse2, mmxext, 3dnowext, 3dnow
Memory: 4k page, physical 2095536k(1448740k free), swap 4033980k(3440544k free)
vm_info: Java HotSpot(TM) Client VM (1.6.0_01-b06) for windows-x86, built on Mar 14 2007 00:24:02 by "java_re" with unknown MS VC++:1310
Sam
Try uninstalling both limewire & java. Install java & then limewire. Dunno if it will work but worth a try if you haven't already.
I see you've already uninstalled java & installed it but was limewire open/installed at the time?
nvappfilter.dll is related to the onboard network card on nforce motherboards , my guess is the firewall part of it.
Are you using that and if you are have you told it to allow Limewire access to the net and also to act as a server i would guess ?
hmmm
I have the nvidia firewall turned off mate :( the windows one is turned one but ive got limewire as an exeption
