I'm not too clued up on the line stats and such although I have picked up a few things from reading on the net. We currently have a 1MB ADSL connection and are looking at going on MAX depending on the amount of "extra" speed we may be able to get.
The line stats are (at present):
With the SNR (down) generally ranging from 23.0 to 27.0 and the Max (attainable rate I take it?) from the value shown up to ~5400. Although what confuses me is that putting the stats into some checkers gives an estimate of 3.5-4.1 (is that throughput or sync?) whilst the Max figure (which I guess would be attainable rate if on MAX) giving throughput between 4.0-4.5.
However, the wonderful BT Checker gives for the house post code:
Yet for our number:
I know that a telephone number check is supposed to be more accurate (although before having 1MB ADSL which was before MAX, our number gave the same results as our postcode). Surely if we can get 2Mbps ADSL we should be able to get more than 2Mbps via ADSL MAX?
Any help is much appreciated (we're looking at ADSL24 btw).
SNR [D/U]: 24.0 23.0
Atten [D/U]: 55.0 31.5
Pwr [D/U]: 17.6 11.8
Max (Kbps) [D/U]: 4832 1024
Rate (Kbsp) [D/U]: 1152 288
According to BT Wholesale, your line should be able to support a 3Mbps or greater ADSL connection via ADSL Max.
Standard ADSL RAG results:
You cannot receive 2Mbps ADSL
You may be able to receive 1Mbps ADSL
You can receive 512Kbps ADSL
You can receive 256Kbps ADSL
Yet for our number:
According to BT Wholesale, your line should be able to support a 2Mbps or greater ADSL connection.
You can receive 2Mbps ADSL
You can receive 1Mbps ADSL
