I'm having problems getting Linx stable with an i5-750 on a GA-P55A-UD3. It never bsods, but always stops with error after anything from 4-8 passes. Running 4GB of generic OEM RAM.
The build is stable with a whole night of prime, and mem test is fine. Load temps are 60 with Linx, and 55-60 with prime.
Currently:
Multiplyer: 19x
BCLK: 200
RAM @ x6, 1200Mhz
VCore: 1.375V
QPI/Vtt: 1.230V
CPU PLL: 1.8V
RAM: 1.5V
I don't really want to go any higher on the voltages though I guess I could bump the cpu up to 1.4V. Would raising the PLL help?
I've never had a crash even when gaming with these settings, so at the end of the day does Linx instability (no bsod) matter for 24/7 usage? Any advice would be great, cheers.
Currently:
Multiplyer: 19x
BCLK: 200
RAM @ x6, 1200Mhz
VCore: 1.375V
QPI/Vtt: 1.230V
CPU PLL: 1.8V
RAM: 1.5V
