- 18 Oct 2002
- North
Im currently waiting for my line to be activated by Be so I thought Id check my wireing out on my Master Socket as stated on DSL Zone http://www.dslzoneuk.net/socket.php
In that site it says you only need 2 wires in slots 2 and 5, and to pull out all others as they are not needed.
However, on mine I only have one wire in slot 3??
Should I call BT?
I also plugged cable in socket under face plate (noticed that has 2 wires conected to that) and my attanible rate has shot up from 8600 ish to 11328. The Attenuation (dB) has stayed the same.
The rest of my specks is here
Connection mode : G.DMT
Type : Fast
Noise margin (dB) : 30.3
Attenuation (dB) : 27.0
Attainable download rate (kbps) : 11328
Should I call BT?
Type : Fast
