Hi Guys,
If possible I would like some advise on memory settings.
I built my new rig last week and at the moment it is set-up like this:-
Mobo P5N-E SLI
E6600
OCZ 2GB (2 x 1GB) PC2-6400 Dual Channel Platinum Revision 2 XTC
425x8 = 3400MHz
4-4-4-12-24-T2
Orthos stable
Idle temps
Core 1 23c
Core 2 24c
load temps around 47c
VCore voltage = 1.4
VCore Offset Voltage = +100mV
Memory Voltage = 2.085
NB Core Voltage = 1.563
I am very happy with that but I am confused over memory settings.
I can get the memory to 4-3-3-8-16-T2 and still be Orthos stable but I am not sure if by running at these settings I am making the system faster or slower.
Is it the lower the numbers the better with RAM? I see in most members sigs that they run at either 4-4-4-12-T2 or 4-4-4-8-T2. Is that because that's the best setting.
I also see no one mentions bank cycle time Trc. On auto mine is at 24 at 4-4-4-8-T2 but I can get it to 16 and still be Orthos stable. Is it okay to lower that or should I leave it at 24?
Many thanks in advance for any advice.
Mobo P5N-E SLI
E6600
425x8 = 3400MHz
4-4-4-12-24-T2
Orthos stable
Idle temps
Core 1 23c
Core 2 24c
VCore voltage = 1.4
