Help with memory selection for new build
25 Aug 2020
Hi all,
I'm building a high-end gaming rig from scratch, no plans to OC initially, but may do so in future.
I've been out of the PC-building game for about 15 years, so fogive the ignorance.
Planning on:
CPU: Ryzen 3600 to get the system up and running, but will upgrade to Zen3 shortly
Mobo: MSI X570 Tomahawk
GPU: RTX 3090
Memory: ???
Questions:
I'm looking for 32Gb of 4,000Mhz(??) memory... is that wise given Zen3 is likely to benefit from > 3,600mhz RAM? Is there likely any value from going higher?
Why is the Corsair memory so much pricier than, say, the 8Pack[url] stuff?[/url]
Patriot viper is probably the stuff you require, search for the 4000 ish kits they do, they are a lot cheaper than corsair.
The other choice is gskill but then you are on the pricier side
