Hello
I hope this is posted in the correct forum.
Would anyone be able to give me some advise on what memory upgrade would be the right choice if any?
I have a media pc that I built in 2009 using a mATX motherboard.
I recently acquired a GTX660 gpu to upgrade the graphics and a Phenom II 965BE as I wanted to play some current games but couldn't afford a whole new system and a 660 seemed like it could handle most current games at medium to high settings.
The problem is that it is still struggling with some of the games I have tried namely -
Need for speed rivals
Assassins Creed 3
Tomb Raider 2013
I suspect that I have a bottleneck and I am guessing that my RAM is the most likely culprit (please tell me if i'm wrong!).
So my question is, if it is my RAM that is holding me back significantly should I upgrade to -
- 4 more GB of DDR2 if I can find a matching kit giving me 8gb DDR2
- or wait and save up a bit more for a new motherboard that supports ddr3 and buy 8gb of ddr3 ram
Also could anyone confirm if adding more ram ddr2/ddr3 would make a noticeable increase in gaming performance or am I barking up the wrong tree so to speak?
If i'm incorrect about the RAM what other upgrade options would anyone here recommend to achieve a better gaming performance?
(I have overclocked the CPU to 3.9ghz and a minor tweak of my current ram timings but that is all)
Thankyou for your help and much appreciated
The spec is as follows -
AMD Phenom II X4 965 - 3.4 GHz Quad-Core (HDZ965FBGMBOX)
ASUS M3N78-VM - Motherboard - micro ATX
Gigabyte NVIDIA GTX660 2GB DDR5 Graphics Card
Corsair 4GB Kit (2x2GB) DDR2 800MHz/PC2-6400 XMS2 Memory Kit CL5 1.9V
Samsung SpinPoint F1 HD103UJ 1TB Hard Drive SATAII 7200rpm 32MB Cache
Assassins Creed 3
Tomb Raider 2013
