Help with memory timings
21 Jan 2007
Hi just want to make sure that i have my memory set up properly.
I have matched pair of giel pc 6400 and a gigabyte ds3 board
here is the cpu-z screen of my memory.
url]
are these settings correct
if not could you please help me set it to the correct one.
Is it the CAS4 Geil?
If so, change the first four RAM timings in your BIOS to 4-4-4-12 and raise the memory voltage (vdimm) to +3 (2.1v).
being new to this could someone please explain what these timing s mean and what effect altering them will have in real terms. ie)a major performance boost or not?
sorry to be a pain but how do i change the memory timings exactly i have altered the voltage to 2.1 but can not findanywhere in the bios to alter the memory timings.
Please help i am getting a headache
tony
hello
I have altered my mem timings to recommended as well as the voltage. A new question has come up now however, should my memory speed be a factor of my processor speed? will i see an improved performance if i alter mem and bus speed to match one another?
does the mem multiplier work in the same way as the cpu multiplier ie)i can reduce mem frequency to 300mhz x 3 to get 900 then increase cpu to 2.7ghz or alt push the cpu to 2.4ghz to match the 800mhz mem.
is this correct or have i misunderstood how it works??
