- 20 Aug 2012
Hi all
I have been looking for a gaming laptop for a while... and just as I find something I like, I hear its got issues
So... found this little case (not going to get it during the deal price I doubt)...
https://www.overclockers.co.uk/showproduct.php?prodid=CA-137-AE
But how to populate it? I have built big tower systems before using OC parts, but never something this dinky.
Like the look of this motherboard -
https://www.overclockers.co.uk/showproduct.php?prodid=MB-136-AK
Which I assume will fit.
That is about as far as I got! I am struggling to find dimensions of boards that will fit.
All the laptops I looked at had GTX980 graphics, so I found this but no dimensions...
https://www.overclockers.co.uk/showproduct.php?prodid=GX-354-AS
So, advice from those who know. What the heck fits this little footprint of a PC?
Budget... £1800. But I would like to get a decent size screen out of that if possible.
Basics?
i7 Intel
Best graphics card that can be recommended to me.
16gb mem minimum (will more make much difference?)
Sound.... motherboard sound should be fine.
Water cooling would be excellent, but might make this an expensive build, and I believe take up some of the fan spaces.
Min 128GB boot SSD (even better- 256GB or 2x 128GB) + a 1 or 2 TB 7200rpm storage standard drive.
Wireless (on the motherboard?).... if not, a wireless card.
I will sit tonight and see how I go, but any helping pointers really welcomed.
Thanks
Basics?
i7 Intel
Thanks
