- 5 Sep 2011
- Nottingham, UK
I need some help.
I am getting a Bit Fenix Shinboi Windowed in the next week or so and looking to mod it a little.
I already have a couple of blue led fans. 1 stock from my current and awful Thermaltake V9 and 2 Bit Fenix Spectre 120mm Blue LED fans which I plan to attach one to the floor and two to the roof to make the inside glow so I can see it from the side window.
I also plan to take the mesh strips from the case and respray them blue and/or the top roof mesh (not sure yet) by spraying them with primer then two coats of blue enamel.
What I need help with is the cable sleeving. I want to have blue cable sleeving on the 24 and 4 pin, 6pin (soon to be two 6 pins with my new card when I get it) and some over cables.
But what I need to know it WHERE do it get them from CHEAP and WHERE FROM?
Also going to add a fan controller on the front to make it look a bit nicer.
So yea, help with the cable sleeving please xD
Thanks all
Thanks all
