Help with monitor choices please
16 Jun 2013
Hello all I need help with a new monitor setup. I currently have 2 acer p223wd but I cannot find a 3rd/the bezel are annoying.
I guess native display port would be best.
So I need 3, minimum 23" thin bezel monitors with VESA mounts (for later wall mount) for design and the occasional game :)
I do a lot of app design, web design and video editing so quality is preferred so I can be as critical as possible :)
Budget for all 3 around £900 I can spend a bit more but only if its truly worth it :)
