Help with MSI RD480 Neo2 Overclocking
23 Aug 2005
Cheadle, Cheshire
Hi all
I have the following....
+3700 SD running at 11x245=2695ghz
2GIG Geil Value Ram at Stock settings
X1800xt 256mb at 685/880
along with the above motherboard....
basically i have upped the FSB as above and have ran prime95 stable for over eight hours but now know that iam running at 5:4 with my RAM....
i tried to change the RAM to DDR400 in the BIOS but in there i change the DDR Memory Frequency to 200 (is this right....no other options).....
and is still says im running the following....
Current CPU Clock 2695Mhz
Current DDR Memory Frequency 203Mhz
could someone please tell me how i go along and run this machine at 1:1 or is it best to leave it as it is....
cheers :D
I would like to know too :)
Got the same board too and cant figure out the clock settings. I have got mine working at the right FSB but it has screwed my timings up and now i cant change them (everytime i try it wont post) im sure this is something im doing wrong though and not the board.
To get my memory running at the same FSB as my CPU i set the TRC to the same as my multiplier (in my case 12). As i said though this slackend my ram timings from 2.5 to 3 so im actually worse off then i was before. Now when i set it to auto it keeps the 223 FSB and crappy timings.
Can anyone help us both? :)
Just noticed you say you only have 200Mhz to pick from. i have 166, 200 and 400 but doesnt seem to make any difference when i changed them.
im sure it was only 200 although i will check later....
need to know this as it is really doing my head in.... :)
anyone help please....
cheers :D
