I need some networking help if possible anyone.
I have a Netgear DG834GT running the GTTeam V1.03.22 - DGTeam Rev. 1018 firmware which gives me WDS (Wireless distribution system) options.
I also have a Thompson ST585 V6 wireless router from my ISP.
I want to connect my LED TV to my network via a wired connection as the wireless dongle is a) expensive b) buggy.
So, how would be the best way of doing this?
I want my setup to look like this;
BT Line > Wireless Gateway > Wireless&Wired Router/Repeater/Bridge > My Devices.
As I understand it WDS mode can only use WEP encyription - which I'm not a fan of but surely having MAC filtering on and not broadcasting SSID will make it secure enough?
Or does anyone have some better ideas than what I am trying to do? If I need more hardware I will buy it - but what should I get to do the job?
I've never tried setting a WDS network up, I presume the Subnet mask needs to be the same across the two routers? WDS needs to be enabled on both routers? SSID's need to be the same on both routers? Enter the MAC's for both routers into each others filtering?
Can I use NAT with WDS?
Anything else I need to try before I get going?
