- 2 Mar 2009
- republic of Agdgdgwngo
I've been trying to configure a cisco ASA 5505 for my home network but I'm not having much joy with it. I've looked at countless guides, tutorials and followed the ASA setup wizard in ASDM. Could someone look at my config and shed some light on where I'm going wrong? Note The Cisco 1841 is running sub-interfaces for my VLAN's
Below is a sample of how my network connects up
Code:
192.168.1.1(Billion router)===192.168.1.2(ASA)192.168.2.1===(Cisco 1841)192.168.2.2 192.168.10.1 192.168.20.1 192.168.30.1
Code:
Result of the command: "sh run"
: Saved
ASA Version 7.2(4)
hostname Bayswater
domain-name drury.local
enable password 2KFQnbNIdI.2KYOU encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.2.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 192.168.1.2 255.255.255.0
interface Vlan3
shutdown
no forward interface Vlan1
nameif dmz
security-level 50
ip address dhcp
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
dns domain-lookup inside
dns domain-lookup outside
dns server-group DefaultDNS
name-server 8.8.8.8
name-server 192.168.1.1
same-security-traffic permit inter-interface
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu dmz 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-524.bin
no asdm history enable
arp timeout 14400
nat (inside) 1 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 192.168.2.1 tunneled
router rip
network 192.168.1.0
network 192.168.2.0
version 1
no auto-summary
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
http server enable
http 192.168.10.0 255.255.255.0 inside
http 192.168.2.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.2.2-192.168.2.129 inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:065cff50cce30b96fe96983a25ebc947
: end
