Ok my pc is in need of a makeover.
my motherboard had given up the ghost i think so time to change.
I have as follows..
AMD athlon XP 3200+
Radeon X800XT PE (AGP)
1 gig of geil ram
80gig H/D
Now I can connect it to my pioneer plasma via VGA which is ok, but I basically need a new motherboard, and case.
It going to be mainly used for games, and thats about it.
Now I want to be able to get Dolby D and DTS from it, now I was going to try and get a good sound card (also something I'd need help with) (Ialso want it to do ES and EX (7.1)
As this will be connecting to my amplifier it needs to have an optical output. However I've been told I can get a motherboard with an optical output (basically to use it as a pre amp) and then use my amplifier as the processor, if that makes sense) and not bother with a sound card all together. So not too sure what to do there.
So, basically what I need is recommendations for..
1, A small case where I can use my existing equipment, i.e graphics card etc.
2, a motherboard thats going to suit my requirements
3, whether i need to get a sound card and if so what one.
I hope this makes sense and if you want me to elaborate on anything I've just tried to explain I'll try and re-word it. I used to be pretty good with pcs once apon a time, but times have changed quickly since I used to be properly into computers!
thanks, Martyn
I have as follows..
AMD athlon XP 3200+
1 gig of geil ram
80gig H/D
thanks, Martyn
