hello,
i am just about to start my first build, i have a budget of around £600 with OS and without monitor.
i am pretty much set on the CPU and would appreciate any advice as to other components.
CPU - AMD Phenom ii x4 965 BE - £125
Mobo - Asus M4A88TD-V EVO/USB3 AMD 880G - £90
GPU - (undecided) PNY Geforce GTX 460 1gb OC - £139/XFX HD Radeon 5850 £139, seems to be very little between these two cards.
HDD - Samsung HD 103SJ spinpoint F3 1 tb - £45
PSU - Coolermaster GX 650W PSU - 6x SATA 2x PCI-E 80plus Certified - £58
RAM - Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit - £35.
Case - Coolermaster Elite 430 Windowed Case - Black - £45
Everything else is undecided at the moment, although there is room for movemet on any of it. Gonna shop around for OS, windows 7 HP 64-bit, but i only bought an upgrade for my laptop 3 months ago.(should have thought it through and got full retail version)
What do you think? (especially on the GPU's)
forgot to say -
i will not be doing anything heavy on it, no video editing etc (maybe at some point but not at the moment). mainly want a good budget gaming rig. cheers
forgot to say -
