Help with my hiS 7950
30 Oct 2008
South
Hi guys, I currently own THIS HiS 7950 and wanted to see what it could be pushed safely to do, so I had a little play in Overdrive in CCC and simply upped the clock from 800 to 900, no memory increase or power increase, I know they are good clockers so I thought a 100mhz increase shouldnt be much issue, so I hit apply and ran unigine and left it running.
After a while my temps were maxxing out at 79 - 80c which I'm wondering is that too high? I have a bit fenix shinobi xl which doesnt have the best intake in the world but I also have a bottom intake which helps a lot. The card reaches the 70's at stock anyway and it hasn't seemed to be a problem but I don't know what these cards can be ran at? Just wondering if I should even be playing, when temps are already what they are without even touching the memory yet. :confused:
Your case is the problem..
The XL (as with the original shinobi) has pretty poor airflow..
I feel its something to do with the awful stock fans.. The spectre's have very poor airflow...
Changing the fans for better ones would be my suggestion.. (or get a new case)
That should see temps go down a bit.
Though as said above you temps are safe so you don't need to worry.. Im just giving advice on what i'd do at a later date
thanx for the advice all, good to hear that 80c isnt going to cause problems :)
As for my case, I have added a 120mm Spectre pro as a bottom intake which helps a lot, that front intake is seriously starved!
looking at that link but my HiS card isnt the ice-q version its a more standard looking card.
How would I go about using a custom fan profile? is there a better piece of software you'd adise over simply using the Overdrive tab in CCC?
