Help With My New Build!!
23 Jul 2007
Hi,
I've just put together my new machine and I can't figure out why it won't start! When I press the power button I get a fash from the LED's on the heatsink then nothing!
I don't know what info I need to supply etc but i'll pass on anything anyone needs to know! Can anybody help me??
Thanks
Clear the CMOS, check you have installed all power cables, ie the extra 12v for the cpu, this will be 4 or 8 pin, check power to gpu.
Also list your full pc specs.
Rob :)
Ok i've checked all of the power cables and everythings fine. I have just taken the mobo out and started it on the box and it was fine. So i'm thinking it's shorting on the case but I can't find where!
My spec is:
Intel Q6600
Asus P5B-E
Tuniq tower 120
4GB Corsair ram
2x Seagate HD's
ATI Radeon X1950 Pro
Corsair HX520W PSU
Everythings fine now! Eventually!
I took everything out and put each part in and tested whether it started or not. In the end it started with everything in place.
Thanks for your suggestions everybody!
