Help with my OC ? :)
1 Feb 2006
Worcestershire
Hi guys,
Ive recently been tinkering about learning how to overclock my newly built system, I'm running an Athlon 64 3200+ (venice), 2gb DDR400 ram, Asus A8N-SLi mobo, 2x 6000gt's, etc etc.
Anyway ive taken the plunge after a few hours of reading up and had the first attempt at overclocking my cpu.
Now if i could show you guys the results and what i've done, id really appriciate any help and advise you could give :)
Here goes..
HTT increased from 200-235 (in small steps)
Multiplier remains x10
HTT multiplier decreased from 5x to 4x
So if im right that gives me 235x4=940 (which is just below 1000 still, so thats ok ???)
Ive also dropped the Ram Freqency from DDR400 - DDR333 to allow for more of a cpu speed increase.
here are a couple of screenies to show you what i get and if its right or sumthings drasctically out !
You'll see i havnt as yet messed with the cpu voltages.
Here is what the Ram is doing, its back upto about 196mhz so is that close enough to 200 again ?
Also what about my Ram timings ?
Thanks for your time
Si :)
Have you tried increasing the FSB to 245?
What RAM is it you have? If you could tell me I could determine the timings @ frequency
Hi :)
Yes the system woulnt boot at 245, and at 240 it failed prime95
The ram is just bog standard Crucial stuff, not sure how i tell, its nothing special tho.
Ok, just to double check, what steps in voltage should i use ?
0.25 ? 0.5 ? or much less/more
Thanks
Ok i tryed 240mhz HTT @ 1.5v for the cpu and it still failed Prime95 in a few seconds, should i push the cpu voltage somemore ?
Ok by what values would you suggest i do those by ?
Sorry for all the questions, making sure i get it right :)
ill lower the HTT divider from 4x to 3x ? (i think thats what you mean), also how do you mean chipset voltage defcon, ram voltage (ddr voltage) as it calls it in my bios ?
thanks
No chipset as in northbridge, the nforce/via bit.
You should have voltage options for cpu, ram and chipset
thats one i dont seem to have for some reason!
Heres what i see:
CPU Frequency
PCI Clock Speed
DDR Voltage
CPU Multiplier
CPU Voltage
also i can adjust the HTT multiplier etc in another menu
no northbridge options atall :(
I think ive cracked it anyway, I' ve now set the DDR voltage from Auto (Presumably 2.5v) to 2.65v
So now with the CPU @ 1.5v, the Ram @ 2.65v and HTT @ 240mhz it 'seems' stable, ive ran Prime95 sofar without hiccup, but ill give it a long term test later to be sure.
How do those settings sound guys, ok ?
Thanks
Si
I may try and squeeze a little more out of it yes, maybe increase the HTT upto 250 if it will take it.
What should i do about my ram Timings tho, atm their 2.5,3,3,7 should i loosen them up a little do you think ? maybe 3,4,4,8 ?
Thanks
