Hi guys, first post here but I’ve been lurking for a while.
I am going to do a full build soon. The only existing component I will be using will be my 19” TFT @ 1280 x 1024 native res.
I am going to put my old rig on an old 17” CRT and wireless network to it. I have to stick to a max £1000 budget for the new rig, as someone else is paying.
I am thinking of the following spec ATM:
Intel Core 2 Duo E6600.
Asus P5B-E Socket 775 motherboard.
2GB DDR2 PC2-6400 800 MHz Dual channel memory.
Nvidia GeForce 8800 Gts 640 MB graphics card.
Enermax Infiniti 650W EIN650AWT ATX2.2 Modular SLI Compliant PSU.
Akasa Eclipse 62 Aluminium Case.
Seagate Barracuda 7200.10 320GB ST3320620AS SATA-II.
Samsung SH-183LBEBN 18x18 DVD±RW Dual Layer Serial ATA Lightscribe ReWriter (Black) – OEM.
2 x Hiper 120mm HiperFlow Chrome Blade Case Fan With Blue LED.
Sony 3.5" Floppy Drive Black – OEM.
Netgear WGR614 Wireless 54Mbps Cable / DSL Firewall Router 802.11g.
Netgear WG111 Wireless USB Adapter 54Mbps 802.11g.
Xpro Silver Wireless Optical Mouse with Cradle - Mains Rechargeable
BTC 9019URFIII Wireless Multimedia Keyboard.
Logitech Z-4 2.1 Speakers With Remote Control.
Google Checkout -£10.
I think all links are to OcUK or non direct selling manufacturers sites (no competitors).
I would like to know what you think of this spec in general, any comments are welcome.
Specifically, I would like a recommendation for compatible memory for the MB. Max budget for the memory is £100.
A couple of points to consider guys.
Most likely I won’t be able to do a major upgrade again for several years.
I know a lot of people recommend the 320 MB gts over the 640MB gts for a 1280 x 1024 display, but I may update my monitor later, so I definitely want to go for the gts 640 MB.
TIA,
Dave
TIA,
Dave
