Hi all. Managed to setup PHP fine and tested it,
know i need to get mysql to run, Ive download the installer from mysql and installed it, On windows 2003 enterprise server,
The thing is i need to know what commands or on the command line
Ive made it so that i create database using the CREATE DATABASE (DBNAME); command,
But how i password protect it ? And do i need to do the use command for the database everytime pc is on, I was hopin of havin more then one sql D active at same time,
Been struggling to get myphp working but i guess when its up will be loads easier to manage sql databases
