Help with Nero. Won't burn discs
23 Nov 2007
Midlands
I've successfully burned hundreds of cd/dvd over the years without any major problems with nero, but suddenly i am having problems with both of my dvd writers and 3 different types of media using nero 7 ultra edition
Here's a log of the fault. Can anyone please help as it's driving me nuts
Rob
1C82-A0K5-19E5-MAAX-400E-7643-****
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.9.6.0
Internal Version: 7, 9, 6, 0
Recorder: <PIONEER DVD-RW DVR-116D>Version: 1.06 - HA 1 TA 0 - 7.9.6.0
Adapter driver: <IDE> HA 1
Drive buffer : 2000kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <JSZSNWT PEF49A3S16 >Version: 1.03 - HA 1 TA 2 - 7.9.6.0
=== Scsi-Device-Map ===
DiskPeripheral : Maxtor 6Y080M0 atapi Port 0 ID 0 DMA: On
DiskPeripheral : WDC WD2500BB-22GUA0 atapi Port 3 ID 0 DMA: On
CdRomPeripheral : PIONEER DVD-RW DVR-116D1.06 JRAID Port 4 ID 0 DMA: Off
CdRomPeripheral : HL-DT-STDVDRAM GSA-4163BA101 JRAID Port 4 ID 1 DMA: Off
CdRomPeripheral : JSZSNWT PEF49A3S16 1.03 at2jd6hv Port 5 ID 0 DMA: Off
=== CDRom-Device-Map ===
PIONEER DVD-RW DVR-116D G: CdRom0
HL-DT-ST DVDRAM GSA-4163B H: CdRom1
JSZSNWT PEF49A3S16 J: CdRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2046MB (2095532kB)
Free physical memory: 1530MB (1566740kB)
Memory in use : 25 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
18.2.2009
Burn DVD Image
19:04:28 #1 SPTI -500 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x00) WinError(1117) NeroError(-500)
Sense Key: 0x00 (KEY_NO_SENSE)
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x00 00 00 00 00 00 00 00 00 00 00 00
Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00
19:05:57 #2 Text 0 File SCSIPTICommands.cpp, Line 424
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
19:05:57 #3 SPTI -500 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x51 00 00 00 00 00 00 00 20 00 00 00
Buffer x04cea7c0: Len x20
19:05:57 #4 Text 0 File Burncd.cpp, Line 3508
Turn on Disc-At-Once, using DVD media
19:05:58 #5 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 1565426 (347:52.26, 3057MB)
19:05:58 #6 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
19:05:58 #7 Text 0 File DlgWaitCD.cpp, Line 2964
Recorder: PIONEER DVD-RW DVR-116D, Media type: DVD+RW
19:05:58 #8 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
19:05:59 #9 Text 0 File ThreadedTransferInterface.cpp, Line 793
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1, Joliet)
2 indices, index0 (150) not provided
original disc pos #0 + 1565427 (1565427) = #1565427/347:52.27
not relocatable, disc pos for caching/writing not required/not required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1565427 blocks [G: PIONEER DVD-RW DVR-116D]
19:05:59 #10 SPTI -500 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x00
Sense Qual: 0x00
19:05:59 #11 SPTI -500 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x00
Sense Qual: 0x00
19:05:59 #12 SPTI -500 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x00
Sense Qual: 0x00
19:05:59 #13 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [G: PIONEER DVD-RW DVR-116D] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3205994496, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 1565427 | 1565427 | 0x00
1565427 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
19:05:59 #14 Text 0 File SCSIPTICommands.cpp, Line 215
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
19:05:59 #15 Text 0 File Burncd.cpp, Line 4294
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
19:05:59 #16 Phase 24 File dlgbrnst.cpp, Line 1762
Caching of files started
19:05:59 #17 Text 0 File Burncd.cpp, Line 4413
Cache writing successful.
19:05:59 #18 Phase 25 File dlgbrnst.cpp, Line 1762
Caching of files completed
19:05:59 #19 Phase 36 File dlgbrnst.cpp, Line 1762
Burn process started at 4x (5,540 KB/s)
19:05:59 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
19:05:59 #21 SPTI -500 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0xAD 00 00 00 00 00 00 00 08 04 00 00
Buffer x06472200: Len x804
19:05:59 #22 SPTI -500 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x00
Sense Qual: 0x00
Buffer x06450b80: Len x20
19:05:59 #23 Text 0 File DVDPlusRW.cpp, Line 675
Start write address at LBA 0
DVD high compatibility mode: Yes
19:05:59 #24 CDR -500 File ThreadedTransferInterface.cpp, Line 1752
SCSI command aborted
19:05:59 #25 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1752
Could not perform start of Disc-at-once
19:05:59 #26 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
19:05:59 #27 Phase 38 File dlgbrnst.cpp, Line 1762
Burn process failed at 4x (5,540 KB/s)
19:05:59 #28 Text 0 File SCSIPTICommands.cpp, Line 261
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
19:06:02 #29 Text 0 File Cdrdrv.cpp, Line 11185
DriveLocker: UnLockVolume completed
19:06:02 #30 Text 0 File SCSIPTICommands.cpp, Line 424
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
OP: try max burn speed detection for all burns. I've had this very nightmare for absolutely no reason at all.... Nero 7 & 9 refusing to burn discs from a pile of 60 DVD and 40 odd CD blanks, both of which worked perfectly before.
Nero will likely tell you your media's duff, your firmware's out of date and/or you're burning too fast.
Max burn speed detection sorted most of my issues, but I'm still getting a niggle now and then.
Strange thing is, I can use IMGBurn, CDBurnerXPPro and Windows' own burner at full pelt and they all just work. Nero though decided just to stop playing about 2 weeks back, for no reason other than it can.
YMMV though and I echo what Ratbag says!
Looks like you have two drives, third one is a virtual drive? You've tried to burn using another drive to rule out that the drive you normally use isn't playing up?
My Nero has also started playing up. It's been working fine for ages, yet now for some reason it starts throwing up a "Power Calibration Error" whenever I try to burn a DVD. CDs burn just fine, it's just DVDs that have started giving this error.
Tried reinstalling nero and also tried Imgburn, but even that throws up an error. I think it's something to do with the DMA or atapi/ IDE controllers, can't see why because i aint messed with them. I've got another Hdd coming in a few days, so i'll just start with a fresh install of xp/vista
I don't want to cast aspersions, but any of you chaps using a 'liberated' serial number by any chance?
Nah, Nero 7 and Nero 9 both paid for. The only stuff that's not paid for are things like Firefox, Thunderbird etc. Got a nice, legit, fully paid up software library here!
The issues I had with Nero have even resorted to a fairly drawn out back and forth twixt myself and Ahead regarding a refund, as it's fairly apparent that 8 & 9 aren't exactly fit for purpose, but they weaseled out of it thanks to the neatly buried clause in the sales agreement that effectively says "you can have a refund within two weeks of sale, unless of course we send you a key electronically, in which case you can sing for it".... credit card provider's now involved though, so I'll let them fight it out.
Well got it all working now. It was something wrong with some settings inside windows somewhere. After a fresh install of xp, it's all working right out the box again.
