Help with Netgear + Cable setup
Permabanned
25 Aug 2007
Hi
My brother has just had Virgin installed in his house. The problem is that the Cable modem is downstairs in the living room but his pc is upstairs!! He told the fitters to put the cable downstairs as he was buying a Router.
Well, he has just bought a Nertgear Cable router and a PCI Wireless adapter.
Can he setup the router wirelessly by installing the wireless adapter first in his PC or does he need to take his PC downstairs and do it through an Ethernet cable?
It's always best to setup a wireless router from a wired connection. He could always take the new router upstairs to the pc and configure it there. The only thing it won't receive is the settings from VM. He should also install the wireless PCI card at the same time and make sure it's talking to the wireless router. When the wireless is all sorted and locked down with WPA, take the router back downstairs and plug it into the cable modem. Once the wireless router has synced with the cable modem the PC should be able to see the router via the wireless and get on the net.
Thanks. Will try that first
So, i can connect the router to the pc via the ethernet cable then once i have gone into the Wireless section of it and activated it i can then put the PCI wireless adapter in the pc, take the router back downstairs and then carry on configuring it upstairs via the PC wireless adapter?
