Hi guys,
My first ever build,
Could do with a little help. I purchased the following items:
Bitfenix Shinobi case
Gigabyte Z68xp motherboard - http://overclockers.co.uk/showproduct.php?prodid=MB-360-GI
Intel i5 2500k CPU - http://overclockers.co.uk/showproduct.php?prodid=CP-360-IN
8GB Corsair Venegence Memory
and a Cool Master Hyper 212 Evo CPU Cooler.
OCZ ZS 550w PowerSUpply.
I have the CPU installed, the cooler installed, my graphics card installed and memory installed.
Motherboard is in the case, all screwed in securely.
Power supply is installed and the ATX connecter is plugged in.
HDD is plugged in, and all connected to the Sata on Motherboard.
All going well.
But, I'm trying to connect my case to the motherboard... Followed the instructions, found out where each one goes such as Power Switch, Reset Switch, HDD LED. The point I got stuck is the power LED...
I have PW LED + and PW LED - - both single "plugs" if you know what i mean? But on the mobo, where it says Power LED + and Power LED - there are 3 "prongs" in a line... But I can only use two... so which two do I use? At the moment its plugged i nthe two end ones, so the middle one is not been used, is this correct? Hope you know what I'm talking about here - I'll try and get a picture later.
Also, the CD-DVD RW I have, I believe is IDE - Do I need a different one?
That's all for now!
All going well.
That's all for now!
