Help with new bundle please
8 Dec 2017
Hi
I recently bougt a new overclocked bundle, installed it. I noticed the CPU should be running at 4.6 but it's running at the stock speed. How do I or where do I find the correct setting in the BIOS to change it?
Thank you
Is there a OC profile saved in the BIOS to load and then save+exit? or any instructions supplied with the bundle?
What program are you using to report the core speed?
I can see an OCUK profile in number #1 in the advanced settings but I'm not sure how to load it. Regarding the core speed I'm just going off the info in the BIOS setup.
Thanks
