Help with new PC configuration
23 Mar 2011
Thanks for the feedback I will use that ram, what are your opinions on the GPUs I was originally looking at two 1gb gainward 560s but saw these had great reviews
I don't think I'll use 2tb of hdd nor the soundcard
really, I think with the money
I save
from that I'll SLI the gfx card. I can always stick my old hdd in it. I'm also only
planning to hAve the OS on the ssd should I grt the crucial 60gb or my original ocz vertex
60gb.
Also should I go for the gainward 560 1gb in sli or the 480super pc above?
well if u only going to put games on it go for the smaller storage option but if u going to watch hd films, mp3s and put quite a few games u will soon find u run out of space
I have managed to fill over 2tb with films, games, demo, photos 1TB would be the best choice really and considering the price of these now would be silly not get at least one
sli will be faster
I don't think there is much difference between the 2 ssd's at 60Gb capacity
This is what i've got atm, any improvements? cooler is out of stock so have not included it in pic. will everything fit in the case & is it the best value for the money ( i'm still not sure about the sli 480's )
Cheers, Chrisvb.
EDIT: i will probably be purchasing an ocz vertex 3, so i have not included it in this spec.
I would water cool yes.
thanks for the reply, i'm thinking just a cpu loop for now, as those gpus seem to run cool with the uprated cooling.
EDIT: if i was planning on getting one gfx card, for around £300, and then upgrade to sli later, what would be the best gfx card?
