Help with new PSU
10 Jun 2010
Coventry
I received my OCZ ZX 1250w PSU today and noticed that when the GPU was loaded the PSU would make a beep, just a single beep. This PSU: https://www.overclockers.co.uk/showproduct.php?prodid=CA-054-OC
I headed over to the OCZ forums and there seems to be a more serious problem with the 20+4 ATX cable where one of the cables melts the plastic. Thread here: http://www.ocztechnologyforum.com/f...ZX1250-with-faulty-modular-20-4-pin-ATX-cable
What do you guys recommend I do?
The last thing I want is to destroy £££ of gear connected to the PSU but at the same time I want/need to use it, hence buying it in the first place.
Seems like a fairly isolated problem - the Cable melting, only brought about by huge Wattage through the GPU...
Also you sure that the PSU is making a beep? Not your Mobo or something?
kd
Definitely the psu, don't have a speaker connected and don't have the issue with my previous psu.
Since I bought it to power a tri 5870 setup I think I have reason to be concerned.
