Hi all
Some advice would be great if possible please...
Building up a system for a friends lad, I've bought all the part from OCUK, delivered Friday and now spent two days trying to figure it out. Spec as follows:
Gigabyte AB350-Gaming 3
Ryzen 5 1600
Corsair Vengance LED 3000MHz 16Gb (2x8)
Palit GTX 1060 Jetstream
EVGA 450W PSU
Crucial 275Gb SSD MX300
Can get it into the bios fine, was on F8 revision and now upgraded to latest F10 - only difference seems the CPU is now at 25deg from 45deg which I thought was a bit hot for idle.
First noticed the problem installing windows 10, got to the first couple of screens, put in the product code and the screen went blank, monitor light started pulsing as on standby. Restarted and tried again, went a few screen further but then same again. Third time got distracted and it seemed to have gone through and restarted but then same issue on booting windows.
Swapped the ram from the two red to the two black slots, then managed to get Windows installed fully and setup, user account and password and onto desktop. Then two minutes later same blank screen and pulsing monitor led.
I've now tried all combination of ram sticks and slots, not much different. Can now just get into windows, put in password and see desktop and then 10-30 seconds later blank screen.
I've just reseated the CPU and cooler, put some better paste on and bios now saying 20deg which is more like it, but am now basically lost as to what to try next.
The ram isn't on the veryfied list for the board, but many other kits are from Corsair for the same speed and amount, so can't see that being a huge problem. The ram is still currently at SPD timings so 2144Mhz and not the 3000Mhz it's rated for either.
I've also tried another screen, so also tried HDMI and DP connections.
Help please!
Ryzen 5 1600
EVGA 450W PSU
Help please!
) But this would allow you to see if you to see if this is a Hardware issue with the MOBO... or a software issue. As if its a hardware issue you should be able to use the PC remotely.
. An update fixed this and let me override this correctly. But i have issue with no display sometimes and I have to take 2 sticks of RAM out, boot up, then re-install the RAM. I would probably go with ASUS or MSI for my next build.
