Help with new system plz
Parts to build
Hi
I am looking for a new system but do not have the time to put one together i know it does not take long but its the buying parts from here and there then havin the time to put it all in place so i am looking to buy a pre built one.
Does anyone know of a decent setup must be in a black case with some silver to match rest of stuff.
I don't do massive gaming or overclock just use for normal stuff i do do movie and photo editing so needs a good size hdd i still have ide drives so would like to move to sata drives.
Also needs to have a card reader and a dvd rewriter which can be made or is multi region also a dvd rom the same multi i know it sound daft but could also do with a floppy drive
I am sure you will all have some ideas what is good and not i have never bought a pre built system before so don't know where to start to look.
I have about £500 to spend!
plz help
Parts to build
Hi
.I am sure you will all have some ideas what is good and not i have never bought a pre built system before so don't know where to start to look.
plz help
