Hi all i've just put together a small machine to use as a file server whith all the following componants
E8200
Asus P5KE WI-FI edition
2x1gb Team X-treme 800hmz
Inno 7200GS 512mb
OCZ Modsteam 600w
(no HHd's connected atm)
I have just turned it on and all the fans turn on and gpu fan is full speed ....
I didn't notice this till i swapped the gpu out for a old x1800 xt due to the screen being blank
So i decided to to go old school and got a mobo speaker plugged it in started up again no beeps .......
Then i thought ill check see if the mobo is duff so i removed all the ram and it amits a error code in beeps
So this brings me to what can cause a fault which wont amit a error code and put all teh fans on full tilt as this is as far as i can go with the fault finding as i dont have any DDR2 ram or a none 45nm cpu to test
Any help would be great thanks
E8200
Inno 7200GS 512mb
OCZ Modsteam 600w
