Help with Northbridge voltage please?
21 Oct 2008
Jarrow
I have my E5200 clocked to 3.2ghz but I have decided to be a little greedy and try and get it up to 3.4/3.5 if possible.
Problem is I cant get it to run for more than a few minutes. It runs 3.1ghz on the minimum volts (1.125v I think) but to get to 3.2 stable I have had to go to 1.3v.
I was reading about upping the northbridge voltage which is on auto, but I cant find the default northbridge voltage for either the E5200 or my MSI P31 Neo2-FR Intel P31 motherboard so I have no idea what is a safe or normal manually set voltage?
I used to run 1.4V on my old MSI P35 NB, mainly to get 4 x 1Gb sticks of ram stable. Temps were fine with that.
Currently running at 1.28V but that's with a P45 board.
