My current configuration is: Outside Cable, drilled through the wall to an internal Junction type box (screwed to the wall inside the house), short NTL cable, NTL Cable Modem, Ethernet cable, Computer.
I’d like to reposition the computer to another room of the house by having the internal junction box moved to an upstairs bedroom. As such I would not need any additional outside cable; if anything the cable would be too long.
Does anyone know if the internal junction box can be moved in such a way, ie drill a different hole, re-route the cable and reposition the Internal Junction box? Does the internal junction box play any other role other than being a connection point? Would NTL have a complaint?
Alternatively, as I really don’t know anything about these things, would I be able to use a cable less router from the NTL Modem? I don’t have a network card in my computer so I’d probably need one of those? That way I wouldn’t have to have the thing moved but it would be a bit of any eye sore, with the junction box, cable Modem and router sat in a corner of a downstairs room. At present I get good connection from NTL and listening to people I work with they often seem to get problems with their land line cable less routers.
Any advice would be gratefully received.
