- 3 Aug 2008
- Bath, England
hi, i'm having a few problems getting my E8400 past 3.6GHz stable. I've ran orthos small FFT which gave an error after about 23 minutes, whilst the blend test ran fine. CPU temps never get above 55 degrees, but i've found in the bios that the north bridge has been hitting 73 degrees  - i'm absolutely sure its this which is causing the instability. Anyone know what Vnb should be to run stable? its on auto atm as i'm not sure what to set it to.
system as in sig, with a zalman 9700 cooler.
cheers
 - i'm absolutely sure its this which is causing the instability. Anyone know what Vnb should be to run stable? its on auto atm as i'm not sure what to set it to.system as in sig, with a zalman 9700 cooler.
cheers
		 thanks for the info
 thanks for the info
