I've got an XFX 7970 and it overclocks to 1050MHz fine but I cant push it all the way to 1125MHz or I get artifacts and then a lockup. I'm monitoring temps and dont go past 71 on GPU.
Would increasing the voltage help and if so what increments should I raise it?
Also, I've read about flashing the 7970 with a different BIOS. Would I get any benefit from this? I presume that all the 7970's out at the moment are reference cards so BIOS's would be interchangable?
Thanks!
Thanks!
