- 5 Aug 2004
AMD 940
Asus M3A79-T Deluxe
Corsair XMS2 4GB (2x2GB) DDR2 PC2-8500C5 TwinX Dual Channel
have just started trying to OC this and so far without changing any volts it is stable at 3.4 by just altering the cpu multi. temps are 49 under full load using and artic 64 pro cooler.
If i go past this it errors when I try and run the AOD stability test.
Tried upping the cpu volts to 1.4 with the same results. Is there anything else I should be looking out for or could anyone point me in the dirrection of an idiots guide
Asus M3A79-T Deluxe
