Help with overclocking i7 8700k
20 Sep 2017
hi guys anyone can help with overclocking my new i7 8700k?, never done overclocking before. Basicly, how much more can overclock my cpu as will be on safe temperature, will take any tips and recomendations. my full set up:
motherboard:rog maximus x hero
cpu:i7 8700k
gpu:gtx1080
watercooling:h115i
power suply:corsair cx750m
case:corsair 780t.
thanks everyone that will drop any tips.
How far you can go will depend on your temps. I stay below 80' in Prime 26.6 custom 1344 and Realbench. As for voltage, again I'm staying below 1.35. This will change if I decide to delid.
Sorry, only just saw this.
Plenty of different guides on YouTube but for a simple OC, up the volts using manual and then multiplier.
Find out what your 'stock' voltage is first, plumb that into your manual voltage and start to up the multi. For example, my stock v is 1.12, I was able to do 4.7Ghz n all cores with that.
