- 27 Apr 2004
- Doncaster, S.Yorks
Hey fellas, i need some help overclocking my C2D rig, as ive moved from a single core AMD to a Dual Core Intel E6300, things are a little different and to be honest im lost and confused...
MB is the Gigabyte DS3
Cpu is the e6300
Ram is the 2gb Ultra Low Latency kit 44412
right..well ive been in the bios and pressed ctrl-f1 and my oh my im confused, some things have changed others have not, but im generally confused about overclocking with such expensive hardware, but i want to do it.
So basically everything is stock in bios, all voltages are stock too (probably the ram needs upping or something)
So if anyone can offer some settings and help and general know how on what to do, also if anyone has a similar rig and has overclocked the E6300 and is stable, would you mind sharing some settings and tips.
Thanks in advance guys, its much appreciated.
Cpu is the e6300
