- 27 Jul 2005
- The Orion Spur
First time owning a non Intel manufactured motherboard in over a decade so pretty confused with all these settings, my last Intel board o/c'd using percentages so any help would be appreciated.
System,
Memory : 2 x 2gb Cosair XMS2 DDR2 rated @ 5-5-5-12 6400 (800mhz)
CPU : E6300 1.86 Revision B2
Motherboard : Asus P5Q Pro
Currently running the system @ 2.8 with the following settings,
I want to try and push the chip past 3gig but want to just check I'm doing things correctly, the FSB strap, should that stay @ auto ?, and the other CPU voltage settings, is it better to set them manually ?, there doesn't seem to be a 'default' setting for the voltages just 'auto' or whatever you set them as manually, so if I do set them manually how do I know what to set them at ?
How do you recommend I proceed?
System,
