Help with overclocking of venice and memory
19 Jun 2004
On the Amiga500
Hi,
Ive been tinkering for sometime with the overclock now and have accepted a low but stable overclock for a while. I decided to try notch it up a bit today but finding a few problems. I have a few questions that need answering but 1st I best tell you my initial setup:
As sig with these settings in Bios:
Venice 3000+ @ 2.25ghz - HTT = 250 x 9, on 1.58v, at 28oC (SL-120 akasa amber fan)
OCZ3200 @ CPU-Z frequency of 160.7mhz. Timings of 2,2,2,5. Divider = 2/1.33 = ~330mhz DDR.
A few issues I need to resolve:
Quite simply the HTT cannot be increased beyond 250, it locks up upon booting. Is this because the chip is locked to 250 or is this a limitation of my cheap mobo?
The multiplier is set to x9. Where is the multiplier normally altered? If it is in the bios setup I dont think my bios supports this option! :(
Although I understand the ram timings are tight I have found that loosening them considerably seems to have no effect on how much further I can push the HTT up. 250 seems to be maximum, even on a higher divider.
Sorry for the same old questions but Im only a noobeh :)
Thanks in advance
I dont wanna have to pull my heatsink off :D
I think that means the following:
OPN: ADA 3000 DAA4BP
Package: 939 OuPGA
1.35V-1.40
65oC max
512k L2 Cache
Rev: DH-E3
CPUID: 2, FF0
Model: 2F, Venice
The A64s are multiplier locked, you can only change them down. Should be in the BIOS somewhere though. Think you might have the voltage a bit high on that chip as well... 1.55V is about the max recommended on air (I personally wouldn't go about 1.5V).
Yes therefore do x8, and you SHOULD be able to boost the HTT higher... ;) Well I hope your Mobo allows it.
u need to turn down the htt from 5x (1000mhz) to 4x(800) or even 3x(600), as u are exceeding the limit on the bus which should not be much higher than 1000.
