- 21 Jan 2003
- Northamptonshire
Hi Guys,
Right currenly i am running the following :-
1 x Connie 6400 @ 400x8 3.2ghz
1 x Bad Axe Rev2 mobo
2 x 2gb Kits of G-Skill 6400HZ mem
2 x 74gb raptors, raid 0
2 x 250gb maxtors raid 0
1 x PoV 8800gts
Now the problem is i cannot o/c any more than 400mhz on the fsb with the bad axe, can some one suggest a good over clockers board which will get me to a better speed.
I used to be able to run 420x9 on the p5w but i switched to the bad axe 2 as i wanted to run my 4 hdd's off a decent raid controller and not the ez raid on the asus.
Open to suggestions please. My mem and such should easily be able to clock higher than it is on the bad axe. if i try changing the mem/cpu ratios the board craps out.
1 x PoV 8800gts
