Specs,
ASUS Crosshair III Formula
AMD Phenom II X6 1055T
Kingston HyperX Blu DDR3 1333MHz
XFX Radeon 6870 1GB
600W Magna PSU
Right, Can any give me some reference settings and some of your expertise to overclock my CPU please
I tried many times to get to 4.0GHz and no luck at staying stable, Tried 1.5V on cpu and 2.6V on CPU VDDA, tried NB and HT link at around 2000MHz as possible, CPU-NB to 1.35 and NB to 1.35, DRAM to 1.6V from 1.5, downclocked RAM to lowest possible but it just won't stay stable on Prime for soo long, but if it does stay stable for at least 30 minutes and i stop the torture test it will just crash.
I'm running at 3.8GHz fine right now at 1.47V on CPU and 2.4GHz on NB and about 2.1GHz on HT Link running stable, still i don't like the voltage the cpu is getting so i will experiment with lowering it later.
But any help would be much appreciated.
P.S i very much would like to keep Cool 'n' Quiet and C1E enabled to keep my cpu temps and wattage down when idle.
Thanks.
XFX Radeon 6870 1GB
600W Magna PSU
Thanks.
