Hi,
I have an I7 920 C0 CPU which I wish to overclock. However it gets very hot even at stock speeds. After 20 minutes of Prime95 it reaches around 78-80C in the 4 cores.
I currently have
MSI X58 Platinum
Corsair Dominator 6GB (3x2GB) DDR3 12800C7 (1600MHz)
Asetek Liquid CPU Cooling System For Intel LGA1366
CoolerMaster Centurion 590 Case with 2 case fans
I think I need to improve my cooling before I can overclock (ideally to 3.5GHZ). What would recommend I get?
I have been advised to go for the Noctua D14 CPU Cooler, 4 140mm fans and "aftermarket heatsinks for the chipset" which I dont' really understand. The Corsair H50 water cooler has also been suggested as an option (is it better or worse than the Noctua?)
Any guidance or suggestions much appreciated
thanks
Jon
I currently have
MSI X58 Platinum
thanks
Jon
