Help with Pacific PR22-D5 Plus
10 Jun 2017
Ok so I have this Thermaltake RGB pump.
The pump comes with a Thermaltake LED controller, and comes with one LED cable. The controller takes I think it’s about 5 cables.
But I cannot find anywhere to buy them?!
The cable needs to be 9-pin usb to a 4 pin LED
Did you buy it brand new? If so then surely it should come with everything you need to get up and running? If something is missing contact the place you got it from. Failing that drop Thermaltake a message and see if they will help you.
Yeah it was brand new, when I read the manual it says it only comes with one LED cable, huge mistake by Thermaltake.
I will try contact Thermaltake and ask them about it, they will probably charge me an overpriced charge for the cables haha!
This pump costs £170 and it doesn’t even come with enough cables! How crazy is that!
I think I didn't understand your question correctly earlier. What I now think you want is extra cables to plug in extra RGB things, yes? I have had a look around and cannot find extra cables anywhere except on other Thermaltake RGB items. Is it possible that they have made this a "closed" system where the only other things you can plug into the controller are their own products? It's looking that way to me, especially after looking at the cables that come with their Ring RGB fans which look identical to the one that comes with your pump/res combo.
Yeah I think your right, crazy that they only sent one cable when spending that amount of money! I have tried emailing Thermaltake to ask them to send me more of the cables, I’m not sure they will reply though :rolleyes:
